Our washer spins and drains, but leaves water in the bottom under the tub and sometimes the clothes are dripping wet still. What part do we need to replace?
I would pull the drain hose sufficiently out of the drain to see if the flow rate appears "normal". If so, you might have a shortened drain period due to a worn timer, particularly if it only does this with a full water level.
