| » Slow final Spin on Frigidare Gallery front loader |
Model Number: 417.39012891 Brand: Frigidaire Age: More than 10 years
Today when I went to empty clean clothes I found them dripping wet. I put washer back into final spin and the drum would agitate then spin but not fast. I removed clothes, removed top and back then tried final spin again looking for a slipping belt but it ran fine but did not sound like a very high speed. I put wet clothes back in and it did spin them dry. I have done two loads since then and it appears to be working now. I am not convinced that it is spinning at the very high speeds as before but clothes are not dripping wet as I first found today. Can anyone shed some light as to what may have happened that my first load today would not spin dry? Appears to be working now but is this the beginning of the end for it?
There is a good possibility your speed control board is going bad, but keep running it as long as it runs well.
There will be tech notes inside the lower service panel which will show you how to test things if the problem comes back.
__________________
| Display Modes | |
| Frigidaire Front Loader won't do final spin | digitalslacker | Washer Repair | 4 | 07-12-2010 05:41 PM |
| front loader won't final spin | cindy53 | Washer Repair | 3 | 05-12-2010 04:37 PM |
| Kenomre front loader wont final spin | CNR | Washer Repair | 14 | 04-01-2010 11:59 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| front loader will not final spin | gillpx | Washer Repair | 3 | 08-04-2008 05:44 AM |
