My kenmore series 80 washer will fill, spin, and drain fine but will not agitate. Timer moves through the entire cycle as it should but in the areas where the machine should agitate - nothing, not even a motor hum. Any ideas on what to check? :confused:
What is the complete model number of the washer?
Originally Posted by: badu789 To the best of my knowledge, it may be the motor coupler. How it can be a motor coupler if the motor itself is silent at that time? Gene.
