| » washer want move |
Model Number: kaws850jq4 Brand: Kitchen Aid Age: 5 - 10 years
washer will fill but want move, smell rubber burning
Open,
Have you removed the cabinet and checked for a seized pump ? There is not belt on your washer, so it would have to be an overheated motor., possibly due to a seaized pump, or something stuck between th tubs or under the agitator. Here are some basic insructions, if you need them. Servicing Components in the Console 1. Remove the two Phillips-head screws securing the front corners of the console to the washer top. 2. Tip the console back on the hinges that secure the top of the console to the washer back. Components inside the washer cabinet can be accessed by completely removing the outer cabinet as one unit. 1. Remove the console mounting screws and tilt the console into the service position. 2. Unplug the lid switch harness connector from the receptacle in the washer top. 3. Remove the cabinet mounting clips by placing the flat blade of a screwdriver in the clip. 4. Remove the cabinet by tilting it forward and pulling it away from the washer. 5. The rear panel can be tilted back for additional access to components at rear of machine by twisting the rear panel support 90°. and then tilting the rear panel back.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washer does not move through cycles | RayJay55 | Washer Repair | 0 | 09-19-2010 07:15 PM |
| Washer arm won't move ! | Pocketchange | Dishwasher Repair | 3 | 07-14-2010 11:43 AM |
| Can't move my washer! | Croftfam | Washer Repair | 1 | 04-17-2009 01:30 PM |
| Washer Won't Move To Next Cycle | BoydJSmith | Washer Repair | 0 | 11-23-2008 09:31 AM |
| Washer Thumping after move | lmcclure1220 | Washer Repair | 1 | 01-21-2008 11:01 AM |
