The agitator turns while the washer is on the fill cycle. Any ideas?
We cannot accurately diagnose without a complete model number. However, I would suspect either a clogged or restricted air line between the tub and the water level switch; or a bad water level switch. To test, discnnect the air tube from the switch and see if the machine fills. Tell us what you find.
