Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   help on installing door gasket to drum on front load washer (http://forum.appliancepartspros.com/washer-repair/22903-help-installing-door-gasket-drum-front-load-washer.html)
df134 02-06-2009 05:43 AM
just replaced the o-ring on the outer drum. put everything back together but having a hard time attaching the boot from the door to the inner drum. are there directions out there that i can download? There is a large spring that is used to hold it in place. what is the trick ongetting this back together?
Don
Gene 02-06-2009 09:04 PM
1 Attachment(s)
The instructions attached to this post are not for this model exactly, but they should help you.
