Discuss
Washer fills, wont agitate, spin, or drain...
 in
Washer Repair
I have a Kenmore 80 series washer that had tripped its circuit in the middle(?) of a cycle. The tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer fills, wont agitate, spin, or drain...
  #1 (permalink)
Old 05-22-2011, 07:22 PM
Junior Member
WeCanDoit is on a distinguished road
Default Washer fills, wont agitate, spin, or drain...
Model Number: 11022882101   Brand: Kenmore   Age: More than 10 years
I have a Kenmore 80 series washer that had tripped its circuit in the middle(?) of a cycle. The tub was full of water that wasnt soapy so i figure it stopped before it drained the rinse water. After engaging the circuit I went through all the different cycles under various settings and got NO action... only humming from the motor. I got online to investigate potential causes and found strong suggetions for faulty coupler or even a faulty pump (since it was not draining either). I pulled the clothes drained the tub and hauled the washer outside for better light and access. I checked the pump and found no problems. I got to the coupler and found their wasn't a thing wrong with any of the three components. I got back online and was compelled to check the capacitor and the motor, did as much, and came up with no problems with either. Put it all back together and ran a small load cycle: the tub filled to level and then only hummed and did as much in all the different cycles that I turned the dial through. I have not allowed it to contiunue to the point of overheating or tripping any circuits. Aarrgghh!
Ads By Google
Related Models
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Kenmore 11026844694 AUTOMATIC WASHER
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
  #2 (permalink)
Old 05-23-2011, 08:06 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You may have a bad motor. Unplug the machine and disconnect the motor from the machine. Leave the motor hooked up to the wiring harness and protect the wires and terminals from any metal contact.Start the machine ina spin cycle and ee if it runs. If it receives 120VAC and just hums, replace it.
  #3 (permalink)
Old 05-23-2011, 10:29 AM
Junior Member
Smile
Quote:
Thanks that's exactly what i needed to hear...when i ran the motor test before i didn't know if the humming(and no spinning) was a good thing or not. I'm off to buy a used one and will inform the forum of the results Thanks magician59; I hope this helps any body else too!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer only fills-won't agitate, spin or drain after filling starrgazer Washer Repair 1 09-12-2010 07:33 AM
washer kenmore 80 series top loader fills with water wont drain agitate or spin out dwills Washer Repair 0 05-27-2010 09:24 PM
washer fills, timer doesn't advance, nor does it agitate, spin, or drain threads68 Washer Repair 3 01-17-2010 01:47 AM
washer fills/ wont drain or spin dave696 Washer Repair 1 05-17-2009 09:25 AM
my estate washer only fills up but wont agitate rinse or spin redbacks12 Washer Repair 0 08-03-2008 09:15 PM
