The washer will fill with water, articulate and drain water in all wash cycles. The washer will not spin after the water drains, the pump will stay on as the timer counts down during the spin process. The lid switch works and the belt is ok. I read on ge's website that I may need to reset the motor, that was to unplug the washer afterward plug back in and open and close the lid six times. This did not work, any help would be great.
I assume you have a model with a mode shifter, so you need to see if any of the lights on the motor are blinking. Those are error codes and there should be a tech sheet inside the console that will allow you to interpret them.
If you need more info please post a model number.
