My maytag neptune is getting to the final stage of washing and gives a OE code. Water is running in and being pumped out continuously.water will not shut off,even when paused. But doesnt do it on the first few fills. Always at the end of the cycle.The rinse and spin cycle.Any help .could it be the water valve,or selenoid? Or is it an electrical board problem?Thank you for any help you can give..Boyd
Boyd, The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets. Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWWGene.
