Discuss
Frigidaire Washer
 in
Washer Repair
All of a sudden, once my regular load of clothes is done washing & rinsing, my washer starts making this
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Washer
  #1 (permalink)
Old 11-07-2007, 03:20 PM
Junior Member
DebS0623 is on a distinguished road
Unhappy Frigidaire Washer
Brand: Frigidaire   Age: 5 - 10 years
All of a sudden, once my regular load of clothes is done washing & rinsing, my washer starts making this loud whining/squealing noise as it is in the spin cycle???? I have taken the clothes out & attempted to just run the spin cycle to see if it does it without clothes in it & it continues.
Could this be a belt or the agitator?? I had washed some bath rugs a few weeks ago & for the most part they fell apart (new) and I had a lot of lint in the bottom of the tub... I ran the washer a few times w/o any clothes to clean it all out. Any suggestions. It's about 6 1/2 years old.
  #2 (permalink)
Old 11-07-2007, 05:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi DebS0623
In order to provide the most accurate advise I need the complete model number of your washer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-08-2007, 05:15 PM
Junior Member
Default Frigidaire model
model FWS850RH0
  #4 (permalink)
Old 11-09-2007, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check (especially after bath rugs have been washed) is the drain pump.
To get the access to the pump (and all other part inside the washer) you have to remove the front panel. Remove screws on both sides on the bottom of the front panel and push the panel down to release it from tabs on sides.
- The part number for the drain pump AP2108084
The drain pump
Also I would recommend to check the drive belt.
- The part number for the drive belt AP3867042
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire washer JEROME BRYSON Washer Repair 1 02-12-2010 07:15 AM
Frigidaire washer tmartin1065 Washer Repair 1 12-24-2009 09:36 AM
frigidaire washer gianoave Washer Repair 1 11-24-2009 04:00 PM
Frigidaire Washer desteele Washer Repair 1 10-15-2009 04:49 PM
Frigidaire Washer ihoganjr@msn.com Washer Repair 1 12-06-2008 12:13 PM
