My washer suddenly stopped draining. It starts fine and seems fine in the agitation cycle, but once it gets to the drain cycle, it stops. Can you suggest what the problem might be?
Thank you
Originally Posted by: gcsampson ...but once it gets to the drain cycle, it stops... Does it make any noise at that time? Gene.
Hello: I went to a local appliance dealership to price new washers and I was told that 90% of the time it is the lid switch, which is a safety feature. I changed it out and it works great again!!!!!
Thank you for all your help!
Gil
