Originally Posted by: dgrant15 frig leaks water drain area is frozen DGrant, You'll need to unplug the power cord, and remove the back wall of the freezer compartment so you can access the defrost drain pan area and some towels or rags to absorb the water. You can use hot water or a hair dryer to melt the ice blockage. Hopefully you'll find the drain blockage there, in the drain opening of the pan. Peas, Corn, and labels seem to be a common problem. but if you don't find the clog there and you still have a no drain, slow drain, you'll need to find a 1/4 in. flexible tube or wire device approximately 4 ft. long, to clear the internal drain line all the way to the drain pan. Good Luck, :) :) :)
