Discuss
Water Valve Replacement
 in
Washer Repair
On part # 22002360 it looks like the "leads" are perpendicular to the hose attachment. On mine that needs
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water Valve Replacement
  #1 (permalink)
Old 11-07-2007, 11:46 AM
Cary Cary is offline
Junior Member
Cary is on a distinguished road
Default Water Valve Replacement
Model Number: Maytag Atlantis MAV-31   Brand: Maytag   Age: 1 - 5 years
On part # 22002360 it looks like the "leads" are perpendicular to the hose attachment. On mine that needs replacing, the leads are parallel....do you know if the top part (the leads) rotates around so that it will mirror my existing valve? Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-07-2007, 12:16 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Cary
I do not think you got the right part. What is the complete model number of your washer?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-07-2007, 12:24 PM
Junior Member
Gene,
Thanks....I can't read the Model # on the back because the decal is corroded. My manual says MAV-31 and it's an Atlantis.
My part looks identical to the 22002360 but where the wires connect to the leads they are in line w/ the water outlet...
  #4 (permalink)
Old 11-07-2007, 12:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Do you have an automated water temperature control option on the control panel?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag has new water valve, but no water ultimatefighter34 Dishwasher Repair 3 11-02-2007 01:02 PM
Water Valve Problem? Dave14 Refrigerator & Freezer Repair 16 10-26-2007 02:56 PM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 11:34 PM
water flow valve BRAND001 Washer Repair 0 07-23-2007 08:05 PM
Water inlet valve gentleben Refrigerator & Freezer Repair 1 07-19-2007 12:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
