| » Maytag neptune HE frontload washer |
Model Number: MAH6500AWW Brand: Maytag Age: 5 - 10 years
I have noticed water around my washer and have not seen any visible signs of leaking around the supply hoses or even the drain hoses. I suspect there maybe something leaking from inside the machine. Where should I begin?
Quote:
You'll need to remove the front panel of the washer, Open, the door, remove the 4 screws and 2 retainers holding the door to the panel, lift up slightly on the door panel and remove the door. Twist out on the smaller upright area of the panel, and pull out until the retainer clips disengage, then lift up on the panel to disengage it from the lower panel clips. you then can reinstall the door(no screws necessary) and start and run a cycle, so you can observe the leak. You can also move the washer out, far enough to get behind it,remove the louvred rear panel in the plastic frame, and observe the rear components for a leak as well.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag Frontload Boot replacement | cokerta | Washer Repair | 1 | 01-13-2010 12:29 PM |
| Neptune frontload washer problems | rwilder | Washer Repair | 2 | 09-17-2009 07:37 PM |
| Maytag neptune Washer | Montana123 | Washer Repair | 1 | 08-13-2009 12:27 PM |
| Maytag neptune washer | PURNRG | Washer Repair | 7 | 08-08-2009 09:03 AM |
| Maytag FrontLoad Neptune Washer | Donna Bouchie | Washer Repair | 1 | 07-25-2009 02:06 PM |
