The washer stops during the wash cycle, the buzzer goes off, the door locks, and the error code of 03 flashes. I followed the instructions and emptied the washer using the drain tube, checked the pump for debris, and checked the drain hose for a clog. The washer continues to stop during the wash cycle and flash an 03 error code.
If you do a search on this Forum you will see very few posts on the Bosch models, and even less replies, in large part because we are just not experienced with that brand.
I recommend you try another Forum that might be more familiar with the machine.
Good luck.
