Recently my washer had started to make a squealing noise when on the spin cycle. It seems to be increasing in intensity with time. Other parts of the cycle it sounds normal. Any ideas what to look for?
Noises like this are hard to diagnose on a Forum, because you need to be present to listen to them and locate the approximate source. Hopefully it is a simple issue like the pump, or something caught somewhere, so open it up and see what you can see.
If you need more info please post a model number and tell us what your inspection found out, if anything.
