There is a grinding sound when the barrel is turning, could it bearings in the motor or something scraping the sides of the barrel?
Originally Posted by: john baran There is a grinding sound when the barrel is turning, could it bearings in the motor or something scraping the sides of the barrel? John, Based on your post, my first guess would be a warn out drum bearing. That would require a rear drum assembly replacement, Part number: AP4412018
Good Luck, :) :) :)
