I have a Maytag Washer and after the cycle it begins to drip on the inside from the inlet....any ideas?:confused:
We need to see a model number to help, and for you to detail exactly where the drip is coming from. Sounds like water is dripping into the tub, is that what you mean, or water dripping out of the tub.
If water is dripping into the tub it is probably the water valve assembly.
yes it is coming into the tub at the same location that the water normally enters....just a constant drip.
Try changing out the water valve assembly.
