Previously fixed the snubber. Thats fine. But now just started to make a loud sound when in spin cycle (is when i noticed it.) It sounds like a jet airplane is about to land...Its like its missing a muffler. Opened the lid and it stoped without any noise. So thinking the brake was fine. But not sure why the loudness is happening. Thanks, K1
This is a Maytag, not a GE, but you probably knew that. Sounds like a bearing replacement is needed, this part here. Part number: AP4025154
It is a straight forward but not too easy a repair, and may need some special tools. It also requires Maytag grease, 203959.
YES Maytag....It does sound like a bearing. So this makes perfect sense. Thanks!
