Discuss
Water barely trickling to fill tub
 in
Washer Repair
My Whirlpool washer barely has water trickling in to fill tub. We replaced the water inlet valve about 9 months
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water barely trickling to fill tub
  #1 (permalink)
Old 05-15-2011, 08:15 PM
Junior Member
lbersosa is on a distinguished road
Default Water barely trickling to fill tub
Model Number: LSR8244EZ1   Brand: -brand-   Age: 5 - 10 years
My Whirlpool washer barely has water trickling in to fill tub. We replaced the water inlet valve about 9 months ago, could this be the same problem again?
Related Models
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
 LSU182HE Air Conditioner
 LSU240HE Air Conditioner
 LSU242CE Air Conditioner
 LSU242HE Air Conditioner
 LSUC121PMA Air Conditioner
 LSUJ0910CL Air Conditioner
 LSUK1830CL Air Conditioner
 LSUK1830HL Air Conditioner
 LSUK2430CL Air Conditioner
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
  #2 (permalink)
Old 05-16-2011, 05:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Remove the hoses at the washer and run them into a pail to check that you have good flow.
Some hoses have a filter screen built into the sealing washer at the tap. Also hoses can de-laminate internally and reduce flow.
If OK.
Take a look into the water vale connectors. They have a filter screen perhaps they are partially clogged.
Clean them if dirty.
Do not permanently remove the filter screens as they are there to prevent crud from getting into the valve, holding it open and causing a flood.
You may have to remove the valve from the unit to do a good job.
If your hose has a hose break protection system these are know to cause problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water trickling into tub catoose Washer Repair 4 02-21-2011 09:27 AM
Water fill is delayed, must wait to have water in rinse cycle sewsmack Washer Repair 0 10-19-2010 02:45 PM
Water dispenser barely flows. bgadams Refrigerator & Freezer Repair 0 03-04-2010 07:36 AM
Hotpoint clothes washer cold water is just trickling in Sarah Gray Washer Repair 1 05-05-2008 03:24 PM
Refrigerator freezing, freezer barely cold, water dispenser frozen aparks Refrigerator & Freezer Repair 0 01-08-2008 11:02 AM
