Discuss
dryer quit heating and water quit filling up on Maytag stackable
 in
Washer Repair
the dryer quit heating and about a week later the washer will not work at all. It was working great
Appliance Repair Forum > Appliance Repair Help > Washer Repair » dryer quit heating and water quit filling up on Maytag stackable
  #1 (permalink)
Old 05-15-2011, 04:59 PM
Junior Member
oldrugrat is on a distinguished road
Question dryer quit heating and water quit filling up on Maytag stackable
Model Number: LTE5243DQ3   Brand: Maytag   Age: 1 - 5 years
the dryer quit heating and about a week later the washer will not work at all. It was working great at the old place, we moved into the new place and had to put in a double pole 30 amp and run new wire, I used a 10/3 wire.
Ads By Google
Related Models
Whirlpool LTE5243DQ3
Whirlpool LTE5243DQ4 Washer/dryer Laundry System
Whirlpool LTE5243DQ5 Washer/dryer Laundry System
Whirlpool LTE5243DQ6 Washer/dryer Laundry System
Whirlpool LTE5243DQ7 Washer/dryer Laundry System
Whirlpool LTE5243DT2
Whirlpool LTE5243DT3
Whirlpool LTE5243DT4 Washer/dryer Laundry System
Whirlpool LTE5243DT5 Washer/dryer Laundry System
Whirlpool LTE5243DT6 Washer/dryer Laundry System
Whirlpool LTE5243DT7 Washer/dryer Laundry System
Whirlpool LTE5243DZ0
Whirlpool LTE5243DZ1
Whirlpool LTE5243DZ2
Whirlpool LTE5500W1
Whirlpool LTE6234AN0
Whirlpool LTE6234AN1
Whirlpool LTE6234AN2
Whirlpool LTE6234AN3
Whirlpool LTE6234AW0
Whirlpool LTE6234AW1
Whirlpool LTE6234AW2
Whirlpool LTE6234AW3
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1
Whirlpool LTE6234DQ2
Whirlpool LTE6234DQ3 Washer/dryer Laundry System
Whirlpool LTE6234DQ4 Washer/dryer Laundry System
Whirlpool LTE6234DQ5 Washer/dryer Laundry System
Whirlpool LTE6234DQ6 Washer/dryer Laundry System
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
  #2 (permalink)
Old 05-16-2011, 06:26 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LTE5243DQ3 LAUNDRY CENTER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Since you used 10/3 I am assuming this unit is a 4 wire hook up and that the old house also used a 4 wire hook up.
Is this correct or is it something else?
The first thing I would check is the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
Neutral to ground should be 0 ohms.
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 05-16-2011, 05:22 PM
Junior Member
Default
thanks so much, your advice wasnt what was wrong but it sent me on the right track. The breaker that I had installed was only hitting on one pole so I was just getting half of the amps needed. thanks again, I dont think I would have gotten it without your help.
  #4 (permalink)
Old 05-17-2011, 05:00 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag DRyer Quit Running bsktcase1114 Dryer Repair 1 08-20-2009 09:53 AM
Whirlpool ice maker quit filling. mikeybrow Refrigerator & Freezer Repair 0 06-21-2008 11:09 AM
Dryer quit heating sdavisokie Dryer Repair 1 05-23-2008 06:26 PM
maytag dryer quit working james001 Dryer Repair 1 10-18-2007 03:01 AM
quit heating marinersfan Oven Repair (including Ranges and Cooktops) 3 10-16-2007 11:44 AM
