Discuss
Whirlpool Duet drum replacement
 in
Washer Repair
I am attempting to replace my duet outer-tub assembly. The typical bearings were gone so I ordered the replacement outer-tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet drum replacement
  #1 (permalink)
Old 05-15-2011, 06:42 AM
Junior Member
U of M Fan is on a distinguished road
Default Whirlpool Duet drum replacement
Brand: Whirlpool   Age: 5 - 10 years
I am attempting to replace my duet outer-tub assembly. The typical bearings were gone so I ordered the replacement outer-tub section. I can't seem to seperate the stainless steel tub from the original outer-tub assembly. Any suggestions on how you push the stainless tub axle out of the plastic outer-shell. I have tried a rubber mallot and can't get this axle to push the drum out. Thanks.
Ads By Google
  #2 (permalink)
Old 05-16-2011, 01:19 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well not sure which Duet you have, but they are all pretty much alike so see if this service manual doesn't help you out.
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
__________________
  #3 (permalink)
Old 05-16-2011, 03:51 PM
Junior Member
Default Whirlpool drum replacement
I have the Duet model GHW9150PW0. I did look at this manual and it doesn't cover what I'm attempting to do. The stainless drum is inside of a plastic outer drum with a spindle between them. I ordered the plastic outer tub, which has the new bearing built into it. My problem is seperating the two. It appears as though the spindle would simply pull right through but it won't pull at all. Not sure if something is holding the two pieces together that I can't see or not. Thought maybe somebody might know the trick to getting these two apart. Thanks.
  #4 (permalink)
Old 05-16-2011, 04:05 PM
Senior Expert
APP Volunteer
Default
Once you have taken off the clamps that hold the two pieces together it should pull apart, but there may be some unseen problem with your machine so I am reluctant to tell you to use all available force.
__________________
  #5 (permalink)
Old 05-16-2011, 04:57 PM
Junior Member
Default Whirlpool drum removal
I have the stainless drum completely out of the machine. It came out with the outer tub around it ( had to remove all the clips to get it out). I can't pull the plastic outer tub off the stainless steel inner tub. As soon as I can get these two apart, I can put the new outer tub over the stainless drum but for some reason the shaft won't pull through the old one.
  #6 (permalink)
Old 05-16-2011, 05:34 PM
Senior Expert
APP Volunteer
Default
I can only suggest you contact Whirlpool and see if they can help you, or take the assembly into a local shop who may be able to work on it for you at a small cost.
__________________
  #7 (permalink)
Old 11-15-2012, 11:28 AM
Junior Member
jesusisholy is on a distinguished road
Smile Jesus really is who he says he is !!!!
about the tub on whirlpool duet. The shaft on basket is froze to the bearing. Did you know that whirlpool puts a 10 year warrenty on the tub and basket. They will send you the complete kit. Basket an tub assembled free. If they tell you they need a appliance repair tech to check it out its still worth it to pay him and do the repair yourself if you know how. It will save you a chunk of money. This way you won't have to take your old basket out. Otherwise you would need to soak the back bearring in lubricant like rust killer or wd40 or whatever solvant you choose.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Rear Tub Replacement Owlmyst Washer Repair 6 11-17-2012 09:07 PM
Whirlpool Duet Washer CCU replacement Jim Nolan Washer Repair 1 06-14-2010 06:46 AM
Duet Dryer Drum Seal Replacement nmfnet Dryer Repair 4 10-08-2009 04:46 AM
Whirlpool Duet - Door Latch Replacement zentmeyer Washer Repair 1 04-26-2009 04:56 PM
Whirlpool Duet Drains Back into Drum Geetch Washer Repair 5 09-23-2008 06:16 PM
