Discuss
agitates but doesn't spin, timer buzzes
 in
Washer Repair
My GE washer (model S3600D0WW) will not fill with water or spin. When starting cycle it immediately starts agitating, but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » agitates but doesn't spin, timer buzzes
  #1 (permalink)
Old 11-05-2007, 08:36 PM
BFSJason BFSJason is offline
Junior Member
BFSJason is on a distinguished road
Question agitates but doesn't spin, timer buzzes
Model Number: S3600D0WW   Brand: GE   Age: 1 - 5 years
My GE washer (model S3600D0WW) will not fill with water or spin. When starting cycle it immediately starts agitating, but not filling with water. When putting it on spin, it will drain but not spin. Even when turned off, the timer makes a buzzing or clicking noise. The only way to stop the buzzing is to unplug the washer. When on, the washer will cycle through but continue on to the next cycle and not stop at the end of the current cycle (i.e. cotton, delicates, etc). I suspected it was the timer and replaced it, but continue to have the same problem. Any suggestions? Thank you in advance for any help provided!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-09-2007, 12:46 PM
Junior Member
Talking Problem solved
The problem is fixed. It was the pressure switch. I disconnected the hose from the pressure switch and blew into it. I was able to pass air through the tube. I then blew in the pressure switch and heard it clicking. I hooked everything back up and it is working great now. Apparently there was either something stuck in the tube or the pressure switch was stuck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer agitates but wont spin maddness35 Washer Repair 3 11-14-2008 06:05 AM
Kitchen Aid Washer Agitates But Won't Spin leroypg Washer Repair 1 10-16-2007 05:01 PM
washer agitates but won't spin` mls6089 Washer Repair 0 10-12-2007 09:34 AM
just buzzes won't start CorrieA Washer Repair 3 09-21-2007 04:40 AM
Washer barely agitates, won't drain or spin jsc2010 Washer Repair 4 09-12-2007 03:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
