| » washer won't spin |
Model Number: sm 8525148-a Brand: Roper Age: 1 - 5 years
goes through the cycles alright but won't spin out
Hi gm589
In order to provide the most accurate advise I need the complete model number of your washer. Instead of the model number you posted a serial number. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hi gm589
If your washer does agitate but does not drain and spin then most likely the problem is a bad lid switch. If does not agitate and spin but does drain then the problem is a bad motor drive coupling. If does agitate and drain but does not spin at all then it could be a bad drive block, a bad clutch or a bad transmission (the transmission should be under the limited manufacturer warranty). To tell you more specific what is wrong with your washer I need more information. - Here are the break down diagrams for the Roper washer Model RAS7133KQ0 Gene.
__________________
The first thing I would check in such situation is the drive block.
Remove the agitator and the spanner nut. Visually inspect the drive block. If it has to be replaced you will have to remove the cabinet and the inner tub. In order to remove the spanner nut you will need a special spanner wrench. - The part number for the spanner wrench AP3538707 - The part number for the drive block AP2905773 The drive block Gene.
__________________
| Display Modes | |
| washer will not spin | chevy2 | Washer Repair | 6 | 03-10-2008 01:47 PM |
| GE washer will not spin | csol147462 | Washer Repair | 9 | 11-09-2007 07:14 PM |
| washer won't spin | dmcleer | Washer Repair | 12 | 11-02-2007 05:28 AM |
| washer won't spin | Craig | Washer Repair | 1 | 09-30-2007 09:33 PM |
| Washer does not spin | Bill Noonan | Washer Repair | 0 | 09-12-2007 06:46 AM |
