I have the model listed above. The tub is tilted to the rear causing the tub to rub on the gasket. I suspect the dampners to be bad. The part number is K610. Where are they located? Do I have to take the back of the panel off to check them? I would assume that they hold the back of the tub up some. I don't need to replace another door gasket.I almost forgot it's a LG front load washer. LG stands for Low Grade.
