Discuss
How to remove washer tub nut
 in
Washer Repair
Hi I am trying to remove the washer tub nut to get at the transmission/clutch/brake assembly, as it has stopped
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to remove washer tub nut
  #1 (permalink)
Old 05-11-2011, 12:54 PM
Junior Member
Biffspagnutz is on a distinguished road
Default How to remove washer tub nut
Model Number: not sure   Brand: GE   Age: 5 - 10 years
Hi
I am trying to remove the washer tub nut to get at the transmission/clutch/brake assembly, as it has stopped working. I have come to a very large nut beneath the agitator column. It is aluminum and reverse threaded, it is larger than the axle nut on my car, and the auto shops like NAPA don't carry anything that large. I tried a pair of channel locks but the nut is corroded in place or just too tight where it is to get any leverage.
Does anyone carry a socket this large or know a way of getting this thing off? I am at the verge of buying new washer because of this one over-sized nut.
Any help or advise at this point would be really great
Related Models
Admiral NR460 REF - SINGLE DOOR
Admiral NR460A REF - SINGLE DOOR
Admiral NR460H REF - SINGLE DOOR
Admiral NR530 REF - SINGLE DOOR
Admiral NR530A REF - SINGLE DOOR
Admiral NR530H REF - SINGLE DOOR
Admiral NR580 REF - SINGLE DOOR
Admiral NR580A REF - SINGLE DOOR
Admiral NR580H REF - SINGLE DOOR
Admiral NR640 REF - SINGLE DOOR
Admiral NR640A REF - SINGLE DOOR
Maytag NS207MA REF - SXS
Maytag NS207MW REF - SXS
Maytag NS207NA REF - SXS
Maytag NS207NW REF - SXS
Maytag NS207PA REF - SXS
Maytag NS207PW REF - SXS
Maytag NS208MA REF - SXS
Maytag NS208MW REF - SXS
Maytag NS208NA REF - SXS
Maytag NS208NW REF - SXS
Admiral NS20F7 REF - SXS
Admiral NS20F7A REF - SXS
Admiral NS20F7H REF - SXS
Admiral NS20F8 REF - SXS
Admiral NS20F8A REF - SXS
Admiral NS20F8H REF - SXS
Admiral NS20H7 REF - SXS
Admiral NS20H7A REF - SXS
Admiral NS20H7H REF - SXS
Admiral NS20H8 REF - SXS
Admiral NS20H8A REF - SXS
Admiral NS20H8H REF - SXS
Admiral NS20JX REF - SXS
Admiral NS20JXA REF - SXS
Admiral NS20JXH REF - SXS
Admiral NS20L7 REF - SXS
Admiral NS20L7A REF - SXS
Admiral NS20L7H REF - SXS
Maytag NS229NA REF - SXS
Maytag NS229NW REF - SXS
Admiral NS22F8 REF - SXS
Admiral NS22F8A REF - SXS
Admiral NS22F8H REF - SXS
Admiral NS22H7 REF - SXS
Admiral NS22H7A REF - SXS
Admiral NS22H7H REF - SXS
Admiral NS22H8 REF - SXS
Admiral NS22H8A REF - SXS
Admiral NS22H8H REF - SXS
Admiral NS22HP8 REF - SXS
Admiral NS22HP8A REF - SXS
Admiral NS22HP8H REF - SXS
Admiral NS22L8 REF - SXS
Admiral NS22L8A REF - SXS
Admiral NS24F8 REF - SXS
Admiral NS24F8A REF - SXS
Admiral NS24F8H REF - SXS
Admiral NS24H8 REF - SXS
Admiral NS24H8A REF - SXS
Admiral NS24H8H REF - SXS
Maytag NT153MA REF - TOP MOUNT
Maytag NT153MW REF - TOP MOUNT
Maytag NT153NA REF - TOP MOUNT
Maytag NT153NW REF - TOP MOUNT
Maytag NT155MA REF - TOP MOUNT
Maytag NT155MW REF - TOP MOUNT
Maytag NT156MW REF - TOP MOUNT
Maytag NT156NW REF - TOP MOUNT
Maytag NT156PW REF - TOP MOUNT
Admiral NT15A5V REF - TOP MOUNT
Admiral NT15A5VA REF - TOP MOUNT
Admiral NT15A5VH REF - TOP MOUNT
  #2 (permalink)
Old 05-13-2011, 04:24 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You can call this parts site to get the special spanner wrench for this, rather pricey and if there is any damage to the nut, you may never get it off.
__________________
  #3 (permalink)
Old 05-13-2011, 08:46 AM
Junior Member
Default
Great I didn't know they had those. Thanks!
  #4 (permalink)
Old 05-13-2011, 08:48 AM
Junior Member
Default
Are there any more specialty tools that I will need to service the transmission/clutch ?
  #5 (permalink)
Old 05-13-2011, 09:32 AM
Senior Expert
APP Volunteer
Default
No special tools needed. You replace the tranny, the clutch is mounted on the motor. Might want to replace the tub bearings/seals, or at least check them while apart.
At the cost of a new tranny and expensive spanner wrench, the money would be better spent on a new Whirlpool direct drive washer, you can get a Roper for $320.
__________________
  #6 (permalink)
Old 05-16-2011, 11:22 PM
Junior Member
Default
Missed your reply until now, thanks for the advise. I got the nut off with out the spanner. I used the channel locks and a 3lbs sledge hammer
I made another post already how do I tell that the transmission/clutch is bad and not a bearing...or something else?
  #7 (permalink)
Old 05-17-2011, 02:16 AM
Senior Expert
APP Volunteer
Default
Don't know much about GE tranny's, if the tub bearings are ok, suspect a bad tranny. Try turning the pulley both directions.
__________________
  #8 (permalink)
Old 05-17-2011, 10:15 AM
Junior Member
Default
Tub not spinning with clothes
Here is the other post
I am being told in the other post it is the clutch or the belt. I can spin the belt one way but not the other.
  #9 (permalink)
Old 05-17-2011, 04:09 PM
Senior Expert
APP Volunteer
Default
If the tranny pulley will not turn in the spin direction, you need a new tranny.
__________________
  #10 (permalink)
Old 05-18-2011, 02:35 PM
Junior Member
Default
Ok I think I diagnosed the problem wrong. I was thinking the tub spin cycle was the agitation cycle
What would cause the agitator not to spin?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help to remove the top washer cover jmquesad Washer Repair 0 04-25-2011 08:39 AM
how do you remove the basket from my washer tlyons Washer Repair 2 09-14-2010 04:13 AM
how to remove washer lid esimo Washer Repair 1 12-23-2009 10:11 AM
need to remove top of washer dhd Washer Repair 1 06-02-2009 02:03 PM
how can I remove agitator out of my washer Mikefabian Heating, Ventilation, and Air Conditioning (HVAC) 1 08-20-2008 12:15 PM
