| » Spins to fast or not at all |
Model Number: MAV8557AWW Brand: Maytag Age: 5 - 10 years
Spin cycle is very noisy (more of a roar than a whine), seems to spin much much faster than normal, a few times would only start spin when started by hand. Motor, belt & pulleys all seem ok. Is this likely the transnmission (in which case it's junk) or something else?
Quote:
It's most likely a bad tub bearing / seal kit, Part number: AP4009444 The easiest way to determine, remove the front panel and start a spin cycle, carefully isolate where the noise is, from the bottom of the tub assembly, you'd have a bad tub bearing. If the noise is down lower, at the base of the machine, You'd need a new transmission. Part number: AP4373431
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Joe, Will keep an eye out for your response. Good Luck,
__________________
| Display Modes | |
| ge washer agitates but drum spins to fast | Panfax128 | Washer Repair | 3 | 12-10-2010 06:45 PM |
| Washer spins fast all settings | busygurl | Washer Repair | 1 | 02-02-2010 04:10 PM |
| Maytag top loader spins too fast | pm1962 | Washer Repair | 1 | 11-20-2009 06:51 AM |
| Basket Spins too fast | wired40 | Washer Repair | 2 | 05-01-2008 06:36 AM |
| spins fast sounds like an airplane noise | starla87 | Washer Repair | 1 | 02-25-2008 01:47 PM |
