Discuss
Can't remove the Washer/TImer Dial
 in
Washer Repair
This could be more of a generic question that pertains to a lot of washers and their timer/wash cycle dial
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can't remove the Washer/TImer Dial
  #1 (permalink)
Old 05-11-2011, 11:53 AM
Junior Member
jerry525 is on a distinguished road
Default Can't remove the Washer/TImer Dial
Model Number: WSM2420SAW   Brand: Hotpoint   Age: More than 10 years
This could be more of a generic question that pertains to a lot of washers and their timer/wash cycle dial on the front of the washing machine.
I happen to have a Hotpoint/GE "Spacemaker" dryer over washer combo.
How do I remove the Dial -- Washer Timer dial that sets the cycles for washing, etc. All the other dials on the front of the washer pull off. The timer dial does not and I don't see a set screw holding it on. On a schematic I saw the parts blow up doesn’t show any set screw or retaining clip.
I do see what looks like it might be a "C" clip right behind the dial but when I try prying it off I see just enough of it that looks like a black plastic washer. It’s smooth on the back side. The side facing the knob assembly however has teeth. That makes sense since when you push the knob in it would engage those teeth so you can set the cycle you want and when you pull the knob out, the washer begins to operate.
Sooooo….that black washer-like thing right behind the knob that has teeth as part of it can’t be the “C” clip others talk about that needs to be pried off so the knob can be removed. If that’s so, what’s holding the knob on??
There’s only about a ¼ inch of space between the knob and the face of the control panel cover. Until I get that knob off, I can’t access a bad lid switch which is behind the control panel cover and which I believe is stopping the washer from going into the spin/emptying mode.
Any thoughts on getting that knob off?
Thanks!
Jerry
Related Models
General Electric WSM2420SAZAA Washer dryer combination
General Electric WSM2420SAZWW Washer dryer combination
General Electric WSM2420SBZAA Washer dryer combination
General Electric WSM2420SBZWW Washer dryer combination
General Electric WSM2420SCZAA Washer dryer combination
General Electric WSM2420SCZWW Washer dryer combination
General Electric WSM2420SDZAA Washer dryer combination
General Electric WSM2420SDZWW Washer dryer combination
General Electric WSM2420SEZAA Washer dryer combination
General Electric WSM2420SEZWW Washer dryer combination
General Electric WSM2420TAAAA Washer dryer combination
General Electric WSM2420TAACC Washer dryer combination
General Electric WSM2420TAAWW Washer dryer combination
General Electric WSM2420TBAAA Washer dryer combination
General Electric WSM2420TBAWW Washer dryer combination
General Electric WSM2420TCAWW Washer dryer combination
General Electric WSM2480D0WW Washer dryer combination
General Electric WSM2480D1WW Washer dryer combination
General Electric WSM2480D2WW Washer dryer combination
General Electric WSM2480D3WW HOME LAUNDRY COMBO
General Electric WSM2480SAZAA Washer dryer combination
General Electric WSM2480SAZWW Washer dryer combination
General Electric WSM2480SBZAA Washer dryer combination
General Electric WSM2480SBZWW Washer dryer combination
General Electric WSM2480SCZAA Washer dryer combination
General Electric WSM2480SCZWW Washer dryer combination
General Electric WSM2480SDZAA Washer dryer combination
General Electric WSM2480SDZWW Washer dryer combination
General Electric WSM2480SEZAA Washer dryer combination
General Electric WSM2480SEZWW Washer dryer combination
General Electric WSM2480TAAAA Washer dryer combination
General Electric WSM2480TAAWW Washer dryer combination
General Electric WSM2480TBAAA Washer dryer combination
General Electric WSM2480TBAWW Washer dryer combination
General Electric WSM2480TCAAA Washer dryer combination
General Electric WSM2480TCAWW Washer dryer combination
General Electric WSM2700DAWCC Washer dryer combination
General Electric WSM2700DAWWW Washer dryer combination
General Electric WSM2700HAWWW Washer dryer combination
General Electric WSM2700HBWWW HOME LAUNDRY COMBO
General Electric WSM2700HCWWW HOME LAUNDRY COMBO
General Electric WSM2700HEWWW HOME LAUNDRY COMBO
General Electric WSM2700HFWWW HOME LAUNDRY COMBO
General Electric WSM2700LAW Washer
General Electric WSM2700LBW Washer dryer combination
General Electric WSM2700LCW Washer
General Electric WSM2700LDW Washer dryer combination
General Electric WSM2700RAW Washer dryer combination
General Electric WSM2700RBW Washer dryer combination
General Electric WSM2700RCW Washer dryer combination
General Electric WSM2700RDW Washer dryer combination
General Electric WSM2700REW Washer dryer combination
General Electric WSM2700TAW Washer dryer combination
General Electric WSM2700TBWAB Washer dryer combination
General Electric WSM2700TBWWB Washer dryer combination
General Electric WSM2700TCWAB Washer dryer combination
General Electric WSM2700TCWWB Washer dryer combination
General Electric WSM2700TDWAB Washer dryer combination
General Electric WSM2700TDWWB Washer dryer combination
General Electric WSM2700TEWAB Washer dryer combination
General Electric WSM2700TEWWB Washer dryer combination
General Electric WSM2700WAWAA Washer dryer combination
General Electric WSM2700WAWCC Washer dryer combination
General Electric WSM2700WAWWW Washer dryer combination
General Electric WSM2700WBAA Washer dryer combination
General Electric WSM2700WBWCC Washer dryer combination
General Electric WSM2700WBWW Washer dryer combination
General Electric WSM2700WCWCC Washer dryer combination
General Electric WSM2700WCWWW Washer dryer combination
General Electric WSM2700WDWWW Washer dryer combination
General Electric WSM2700WEWWW Washer dryer combination
General Electric WSM2780DAWWW Washer dryer combination
General Electric WSM2780DBWWW Washer dryer combination
General Electric WSM2780HAWWW Washer dryer combination
General Electric WSM2780HBWWW HOME LAUNDRY COMBO
General Electric WSM2780HCWWW HOME LAUNDRY COMBO
General Electric WSM2780HDWWW HOME LAUNDRY COMBO
General Electric WSM2780HFWWW HOME LAUNDRY COMBO
General Electric WSM2780LAW Washer
General Electric WSM2780LBW Washer dryer combination
General Electric WSM2780LCW Washer
General Electric WSM2780LDW Washer dryer combination
General Electric WSM2780RAW Washer dryer combination
General Electric WSM2780RBW Washer dryer combination
General Electric WSM2780RCW Washer dryer combination
General Electric WSM2780RDW Washer dryer combination
General Electric WSM2780TAW Washer dryer combination
General Electric WSM2780TBWAB Washer dryer combination
General Electric WSM2780TBWWB Washer dryer combination
General Electric WSM2780TCWAB Washer dryer combination
General Electric WSM2780TCWWB Washer dryer combination
General Electric WSM2780TDWAB Washer dryer combination
General Electric WSM2780TDWWB Washer dryer combination
General Electric WSM2780TEWAB Washer dryer combination
General Electric WSM2780TEWWB Washer dryer combination
General Electric WSM2780WAWAA Washer dryer combination
General Electric WSM2780WAWWW Washer dryer combination
General Electric WSM2780WBAA Washer dryer combination
General Electric WSM2780WBWW Washer dryer combination
General Electric WSM2780WCWWW Washer dryer combination
General Electric WSM2780WDWWW Washer dryer combination
General Electric WSM2780WEWWW Washer dryer combination
General Electric WSM2781WBWWW Washer dryer combination
General Electric WSM2781WCWWW Washer dryer combination
Whirlpool WSR25D2RYB00 REFRIGERATOR
Whirlpool WSR25D2RYF00 REFRIGERATOR
Whirlpool WSR25D2RYW00 REFRIGERATOR
Whirlpool WSR25D2RYY00 REFRIGERATOR
Whirlpool WSR413YW0 WATER FILTRATION SYSTEM
General Electric WSRE5260D0WW Washer
General Electric WSRE5260D1WW Washer
General Electric WSRE5260DCWW Washer
General Electric WSSE4220A0AA Washer
General Electric WSSE4220A0WW Washer
General Electric WSSE5210B1CC Washer
General Electric WSSE5210B1WW Washer
General Electric WSSE5210B2CC Washer
General Electric WSSE5210B2WW Washer
General Electric WSSE5210B3CC Washer
General Electric WSSE5210B3WW Washer
  #2 (permalink)
Old 05-24-2011, 04:45 PM
Junior Member
bushytale is on a distinguished road
Default removing dial
Try turning dial stem counter-clockwise. The top cover part of my dial broke off. Washer still works, so I'm online to find the part.
So I'm not sure you can get to the stem. The wording on the dial plate is still on the washer, I just have the black plastic knob part. In two pieces.
You may have fixed it by now. Hopefully.
B.
  #3 (permalink)
Old 05-25-2011, 08:08 AM
Junior Member
Thanks Bushytale
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to remove the Timer Controller Dial ralphW Washer Repair 2 03-07-2011 07:51 AM
Timer dial removal Tom C Washer Repair 7 01-12-2011 04:41 PM
Washer knob and timer dial former teacher Washer Repair 1 08-07-2010 02:19 PM
How Take Off Dial Timer AZULMARINO Washer Repair 1 05-24-2010 06:44 AM
Knob & Dial Timer Removal on Sears Washer RFaust Washer Repair 3 01-07-2010 02:15 PM
