Discuss
Questions about motor in my Maytag washer
 in
Washer Repair
Dear Sir, I checked my 5-year old Maytag (Norge) washer (Model Number MAV6000AWW, single belt) and have some questions
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Questions about motor in my Maytag washer
  #1 (permalink)
Old 11-05-2007, 10:36 AM
yzhong yzhong is offline
Junior Member
yzhong is on a distinguished road
Default Questions about motor in my Maytag washer
Model Number: MAV6000AWW   Brand: Norge   Age: 1 - 5 years
Dear Sir,
I checked my 5-year old Maytag (Norge) washer (Model Number MAV6000AWW, single belt) and have some questions on its motor. After laying down the washer to front so could look at the bottom. The motor pulley was not fixed to a spot, instead it could slide in a certain range. In addition the motor pulley was not on the same flat level of the agitator and pump pulleys. It was not parallel to the base, instead it had an angle to the base.
When I started the washer without the belt on the motor, the motor ran but its edge touched its metal base and generated friction noise. When I started the washer with belt on the motor, agitator, and pump, as soon as the motor started, its pulley shifted toward the other two pulleys, then the belt loosed and the motor stopped.
Questions:
(1) Should the motor pulley be fixed to a spot therefore is not slide in a certain range?
(2) If yes, how to fix it to a spot?
Thank you very much in advance for you help.
Adam
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-05-2007, 08:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi yzhong
The motor pulley should not move on the motor shaft. Most likely the pulley on your motor is worn out. I would recommend to replace it.
The new part comes with the installation instruction.
- The part number for the motor pulley AP3959676
- Here are the break down diagrams for the Maytag washer Model MAV6000AWW
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Check Washer Motor & Capacitor mickey11 Washer Repair 2 06-15-2008 10:09 AM
GE Washer - Motor Intermittent rmfield Washer Repair 3 11-01-2007 09:01 PM
Washer motor spins but will not agitate. jimmyr Washer Repair 1 09-19-2007 05:34 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Amana stove: Two questions smokysun Oven Repair (including Ranges and Cooktops) 0 08-06-2007 03:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
