Discuss
G.E. Washer WCVH6260HWW leaks on floor
 in
Washer Repair
Hello, I was looking for a little help, I own a G.E. WCVH6260HWW front loading washing machine. It has started
Appliance Repair Forum > Appliance Repair Help > Washer Repair » G.E. Washer WCVH6260HWW leaks on floor
  #1 (permalink)
Old 05-10-2011, 07:28 AM
Junior Member
absynthe714 is on a distinguished road
Default G.E. Washer WCVH6260HWW leaks on floor
Model Number: G.E. WCVH6260HWW   Brand: GE   Age: 1 - 5 years
Hello, I was looking for a little help, I own a G.E. WCVH6260HWW front loading washing machine. It has started a major leak on the floor. I cleaned the pump filter out, (it was horribly clogged, so I thought that was the problem) but when I ran it again, it still leaked. I then took the filter out again, and water came out, about an eighth of a buckets worth. Since I am NOT a washer expert, I was thinking the pump may be bad, but I hear that there might be a blockage in the impeller blades. With the filter being there, how likely is this? If the pump is bad, is it easy to replace? Also, is it worth it to fix it? Or should I just buy a new one. I found the pump part and it was basically $130.00. Also, Being the part is that expensive, is there another thing that could be wrong based on these symptoms? I would hate to buy it and have that NOT be the problem. Any assistance here would be greatly appreciated. Thanks in advance.
Ads By Google
Related Models
Jenn-Air G0206B-8 Electric Grill Outdoor
Jenn-Air G100 Surface Unit - Ddraft Ele
Jenn-Air G101 Surface Unit - Ddraft Ele
Jenn-Air G102 Surface Unit - Ddraft Ele
Jenn-Air G103 Surface Unit - Ddraft Ele
International G1110PRA Range - F/s Std Gas
International G1110PRW Range - F/s Std Gas
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Frigidaire G30NL5 Frg(v2) / Gas Range
Frigidaire G30NL6 Frg(v2) / Gas Range
Frigidaire G30NL7 Frg(v4) / Gas Range
Frigidaire G30NW1 Frg(v5) / Gas Range
Frigidaire G30NW2 Frg(v6) / Gas Range
Frigidaire G30NW3 Frg(v7) / Gas Range
Frigidaire G30NW4 Frg(v8) / Gas Range
Frigidaire G30NW5 Frg(v1) / Gas Range
Frigidaire G30NW6 Frg(v1) / Gas Range
Frigidaire G30NW7 Frg(v3) / Gas Range
Frigidaire G30PCL0 Frg(v7) / Gas Range
Frigidaire G30PCL1 Frg(v7) / Gas Range
Frigidaire G30PCL3 Frg(v2) / Gas Range
Frigidaire G30PCW0 Frg(v8) / Gas Range
Frigidaire G30PCW1 Frg(v8) / Gas Range
Frigidaire G30PCW3 Frg(v1) / Gas Range
Frigidaire G30PNL1 Frg(v2) / Gas Range
Frigidaire G30PNL2 Frg(v2) / Gas Range
Frigidaire G30PNL3 Frg(v4) / Gas Range
Frigidaire G30PNL4 Frg(v6) / Gas Range
Frigidaire G30PNL6 Frg(v2) / Gas Range
Frigidaire G30PNL7 Frg(v2) / Gas Range
Frigidaire G30PNW1 Frg(v1) / Gas Range
Frigidaire G30PNW2 Frg(v1) / Gas Range
Frigidaire G30PNW3 Frg(v3) / Gas Range
Frigidaire G30PNW4 Frg(v5) / Gas Range
Frigidaire G30PNW6 Frg(v1) / Gas Range
Frigidaire G30PNW7 Frg(v1) / Gas Range
International G3110PRA-M Range - F/s Std Gas
International G3110PRA5K Range - F/s Std Gas
International G3110PRW-M Range - F/s Std Gas
International G3110PRW5K Range - F/s Std Gas
International G3127WRA Range - F/s Std Gas
International G3127WRA-3 Range - F/s Std Gas
International G3127WRA-4 Range - F/s Std Gas
International G3127WRA-5 Range - F/s Std Gas
International G3127WRV Range - F/s Std Gas
International G3127WRV-3 Range - F/s Std Gas
International G3127WRV-4 Range - F/s Std Gas
International G3127WRW-3 Range - F/s Std Gas
International G3127WRW-4 Range - F/s Std Gas
International G3127WRW-5 Range - F/s Std Gas
International G3127XRA-5 Range - F/s Std Gas
International G3127XRW-5 Range - F/s Std Gas
Frigidaire G31BFH0 Frg(v3) / Gas Range
Frigidaire G31BFH1 Frg(v6) / Gas Range
Frigidaire G31BFL0 Frg(v2) / Gas Range
Frigidaire G31BFL1 Frg(v5) / Gas Range
Frigidaire G31BFW0 Frg(v1) / Gas Range
Frigidaire G31BFW1 Frg(v4) / Gas Range
Frigidaire G31BPNL1 Frg(v2) / Gas Range
Frigidaire G31BPNL2 Frg(v4) / Gas Range
Frigidaire G31BPNL3 Frg(v2) / Gas Range
Frigidaire G31BPNL4 Frg(v2) / Gas Range
Frigidaire G31BPNL5 Frg(v2) / Gas Range
Frigidaire G31BPNL6 Frg(v2) / Gas Range
Frigidaire G31BPNW1 Frg(v1) / Gas Range
Frigidaire G31BPNW2 Frg(v3) / Gas Range
Frigidaire G31BPNW3 Frg(v1) / Gas Range
Frigidaire G31BPNW4 Frg(v1) / Gas Range
Frigidaire G31BPNW5 Frg(v1) / Gas Range
  #2 (permalink)
Old 05-10-2011, 07:56 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Absythe,
Are you sure the leak is not from the drain pipe(it may be partially clogged and backing up) ?
When you removed the access panel, did you notice/see water on the bottom/base interior of the washer ?
Here are some instructions for accessing and removing the drain pump, it should help quite a bit,
To remove the service panel:
Remove the 3 Phillips-head screws that hold the
service panel to the cabinet at the bottom of the panel. Pull the service panel down.
To remove the pump:
Remove the service panel.
Caution:
Under normal conditions, approximately
1 quart of water will drain out when the pump
cleanout is removed.
Place a shallow pan under the drain cleanout.
Turn the pump cleanout counterclockwise
approximately 2 turns, then pull outward.
Note:
Remove any debris or foreign objects from the
strainer and interior of the pump before reinstalling.
Remove the drain hoses from the pump:
Note:
The drain hoses are difficult to remove.
Squeeze each clamp and slide it back.
Carefully break each hose loose by inserting
a small fl at-blade screwdriver under the
hose to break the seal.
Remove the tub outlet hose from the pump
inlet.
Remove the drain hose from the pump
outlet.
Disconnect the 2 wires from the pump.
Remove the 2 Phillips-head screws that hold the
pump to the chassis.
Pull the pump rearward to clear the 2 locator
pins from the 2 grommets in the front frame.
Remove the pump thru the enlarged opening on
the left side of the front frame.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-10-2011, 12:39 PM
Junior Member
Hello, and thanks alot for that. I did all of that and I tested the pump and it is functioning and all of the pipe downstream from the pumo are clear. However, yes, there is water on the inside. Could something be clogging up the pipes BEFORE the drain pump?
  #4 (permalink)
Old 05-10-2011, 12:44 PM
Junior Member
What I mean to say, is there anyway there could be a clog between the inside of drum and the pump? The hose coming into the pump is clear, but where is the drain from inside the washer?
  #5 (permalink)
Old 05-10-2011, 01:39 PM
Senior Expert
Default
Absynthe,
You have 2 large hoses at the drain pump connections.
One hose goes out the back of the washer and attaches to the drain pipe.
One goes up and attaches to the outer tub, you would follow he same instructions, but the flexible hose going up to the tub is the hose you'd loosen and remove from the tub connection and check for an obstruction. Otherwise, you'll need to remove the top,front panel assembly, boot and tub cover to access the interior of the outer tub, to check for a possible obstruction.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 05-12-2011, 08:02 AM
Junior Member
Hello, and thanks. I actually was in the process of getting started on what Joe had suggested to check the drain pipe. I was looking at the boot to see how hard this project would be, when I discovered that the boot had a big rip in it. This is the gray rubber piece that is between the entrance and the drum. That being ripped, is there a possibility that that is the ENTIRE cause of the leak? I mean it is obvious that it would cause a bad leak. What causes that to rip like that? I would figure that that is the problem, but I would like confirmation that that would cause the huge amount of leakage I have and how to prevent that happening in the future. Also how hard is it to replace? Thanks again for any help.
  #7 (permalink)
Old 05-12-2011, 12:47 PM
Senior Expert
Default
Absynthe,
Yes, a torn boot could be the whole problem. In most cases it is caused by an article falling into the boot when loading or unloading the washer, or articles left in the pockets.
It's an easy repair, it's really involved though,
To remove the top panel:
Remove the 3 Phillips-head screws that attach
the top cover, then pull the cover rearward.
Note:
It may be helpful to place a putty knife along
the top seam between the cover and control panel,
then tap lightly rearward.
Remove the 3 (7-mm) hex-head screws that attach the rear of the top panel to the cabinet. Slide the top panel rearward 1 inch then lift the
panel.
Remove the 3 Phillips-head screws that hold the service panel to the cabinet. Pull the service panel down.
To remove the control panel assembly:
Remove the top panel. (See
Top Panel.)
Pull the dispenser out to the stop position. Press down on the lock tab. Pull the dispenser out. Remove the single Phillips-head screw from the
control panel dispenser recess.
Remove the 4 Phillips-head screws that attach the top of the control panel to the control panel
cover.
From inside the cabinet, lift and push forward to
release the bottom tab from the front bracket. Lift the top edge of the panel to disengage the 3 tabs that hold the top of the panel in place. Push the control panel towards the left, then release the side tab. Disconnect the 9 wire harnesses from the
control panel.
The door lock is held to the front panel with 3 Phillips-head screws. The door lock is accessed from the front of the washer when the right side of the
gasket is partially pulled back.
To remove the door lock :
door lock to the front panel.
Use a long-nose pliers to grasp the wire loop at the spring location and expand it to clear the gasket.
Remove the spring and wire from the gasket. Pull the right side of the gasket away from the
front panel. Pull the door lock to the opening and remove the 3 wire harnesses.
To remove the front panel:
Remove the control panel. (See
Control Panel.)
Remove the service panel. (See
Service Panel.)
Open the door. Remove the 3 Phillips-head
screws that hold the door lock to the front panel.
Position the gasket behind the front panel door opening. Close the door.
Remove the 4 Phillips-head screws that attach the front panel to the cabinet.
Lift up then remove the front panel from the 2 hooks.
To remove the tub gasket:
Remove the front panel.
Pull down and disengage the gasket from the nozzle.
Note:
When reinstalling the nozzle to the gasket, it
may be helpful to remove the nozzle from the hose.
Ensure that the washer is placed on the outside
and that the nozzle is aligned with the indent on the
inside of the gasket.
Disengage the gasket from the water inlet pipe.
Loosen the 7-mm bolt that holds the wire and bolt assembly to the outer tub lip. Remove the wire and bolt assembly from the tub gasket.
Note:
When reinstalling the wire and bolt, tighten
to a gap of approximately 1
1/4 inches. Do not overtighten.
Pull the tub gasket off the outer tub lip.
Note:
When reinstalling the tub gasket on the
outer tub, align the notch in the gasket with the
arrow located on the top of the outer tub lip before
tightening the wire and bolt assembly.
It looks and sounds bad, but it's not really.
Part number: AP4334050
Good Luck,
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 05-13-2011, 07:25 PM
Junior Member
Default g-e-washer-wcvh6260hww-leaks on floor
Hello, Thanks to you Joe, my washer is fixed. I cant beleive that with some questions here, I got the answers I needed. I had called G.E. Repair and had talked to a tech, and all he was interested in doing was making a service call. I am the kind of person that when 1 thing is askew(like a broken washer and piled up laundry) it really bothers me until it is resolved. Thanks man, really. I appreciate the help without any gain for you in return. A very, very rare thing these days indeed. You are providing an invaluable service. Good Kharma to you dude.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaks water on floor in front of freezer Recoop Refrigerator & Freezer Repair 2 11-21-2009 02:45 PM
freezer leaks water on floor and freezes in floor bcarolan Refrigerator & Freezer Repair 10 04-04-2009 10:52 AM
refrigertor leaks water on floor pamela 333 Refrigerator & Freezer Repair 1 09-22-2008 09:21 PM
kenmore fridge leaks on floor mikkonen Refrigerator & Freezer Repair 1 07-23-2008 06:33 PM
My Maytag washer leaks onto floor mbrew5335 Washer Repair 5 12-27-2007 09:07 AM
