We have a well vs. city water. When I purchased this washer it never beeped for the first few months. Then it started every minutefor the first minutes. If I push pause and then start it stops beeping but as I said just for a minute. This stops at about 31 minutes but varies per load. Sometimes it does not happen (rarely). Othertimes it willnot happen until the 23 minute mark. I had the bellow replaced and the repair fellow cleaned andgreased things up...it stopped beeping for about 2 weeks. It has resumed however. It is annoying. Any ideas about how I can stop the beep Is there a filter I may have to clean? If so how do I do this? Ideas readily accepted:eek: .
There are filter in the water valve that your water hoses hook up to. Shut your water off, and take the hoses off the washer, and get a thin screw driver, and pop the screans out of the water valve that is attached to the washer, and clean them. Also, on some hoses, there are filter screans on each end. Check and clean those too. Tom ApplianceEducator.com
