Discuss
Washer Spinning Not Working
 in
Washer Repair
During the spinning cycle, water is being discharged but it is not spinning. During the spin cycle, a buzzing/grinding
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Spinning Not Working
  #1 (permalink)
Old 11-04-2007, 09:27 AM
jimwhite jimwhite is offline
Junior Member
jimwhite is on a distinguished road
Question Washer Spinning Not Working
Model Number: LSQ9110LW   Brand: Whirlpool   Age: 1 - 5 years
During the spinning cycle, water is being discharged but it is not spinning. During the spin cycle, a buzzing/grinding sound can be heard from the bottom of the washer. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-04-2007, 07:33 PM
Hopper Hopper is offline
Junior Member
Hopper is on a distinguished road
Default
I had the same problem. Look under the washer you'll probably find a small pile of shredded black rubber. If so, its the direct drive coupling. New part is about $12 + shipping. Remove the shell, disconnect the water pump and motor. Install new coupling (3 pieces). New improved parts did not fit smoothly. I had to gently tap them with a hammer to fully seat them on the motor and gearshafts.
  #3 (permalink)
Old 11-05-2007, 05:17 PM
Junior Member
Default
I did not notice any shredded black rubber but will check the coupling. I'm not sure that I even know where the pump is located but will give it a go. Thanks for your advice.
  #4 (permalink)
Old 11-13-2007, 10:46 AM
LadyChatfield LadyChatfield is offline
Junior Member
LadyChatfield is on a distinguished road
Default
Our Whirlpool washer motor cycles but the basket stopped moving. I did find two piles of ground rubber under the washer. Your post helped. Thanks for the advice.
  #5 (permalink)
Old 11-14-2007, 04:03 PM
Junior Member
Smile Whirlpool Direct Drive Coupling
Hopper, while I did not find any shredded black rubber, after removing the direct drive coupling (three separate pieces that fit together), the white piece closest to the gear case was cracked completely through. I've ordered the part and am still waiting for it to be delivered. I suspect this is the problem but will not know for sure until I get it installed. I also did not need to remove the shell in that everything was accessible from the bottom. Hopper, your advice was terrific and I appreciate it.
  #6 (permalink)
Old 11-15-2007, 01:20 PM
Junior Member
Talking Whirlpool Spinning Solution
My Whirlpool washer stopped spinning and was making a squealing sound. I ordered and installed the new direct drive coupling ($20 including shipping) and the problem is solved. I was able to replace the part in less than an hour.) I replaced the part from the bottom of the washer without removing the shell. I removed the white plastic water pump first by releasing the two clasps and pushing it to the side. There was no need to remove any hoses from the water pump. Next I removed the motor by removing two electrical connections--one multi-pronged and one single prong black wire (very easy). I then removed two small screws from clasps holding the motor. Once the clasps were removed, the motor came right off. Under the motor was a flat plate with two bolts. I'm not sure that I even needed to remove the plate. It may have made it a little easier to get to the direct drive coupling. The direct drive coupling (a black component sandwiched by two white components) was exposed. I quickly noticed that the white piece closest to the gear box was cracked. I installed the new part (better quality now with a metal insert in the white plastic) and reversed the procedures to reassemble. I appreciate applicance parts pros having this forum and for those individuals sending me responses.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire Washer not spinning sprout69 Washer Repair 6 10-22-2007 05:58 AM
washer timer / not spinning pbush412 Washer Repair 0 09-05-2007 11:32 PM
washer stopped spinning leagleson Washer Repair 0 09-04-2007 11:18 AM
Dish washer not working sylvia Dishwasher Repair 1 07-19-2007 12:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
