Discuss
kenmore 80 series spin problem
 in
Washer Repair
Washer agitates, rinses, drains, but does not always spin when going through the timer cycle. WHile monitoring when it enters
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore 80 series spin problem
  #1 (permalink)
Old 01-25-2009, 11:01 AM
Junior Member
jk85692 is on a distinguished road
Default kenmore 80 series spin problem
Model Number: 23832100   Brand: Kenmore   Age: 5 - 10 years
Washer agitates, rinses, drains, but does not always spin when going through the timer cycle. WHile monitoring when it enters spin cycle and doesn't spin, it does begin spinning when I release and reativate the lid switch Changed out the lid switch. Same result. Any thoughts on where to look next?
Related Models
Roper 2384*0A Ranges, Electric*
Roper 2384*1A Ranges, Electric*
Roper 2384*2A Ranges, Electric*
Roper 2384*3A Ranges, Electric*
Roper 2384W0A Ranges, Electric*
Roper 2384W1A Ranges, Electric*
Roper 2384W2A Ranges, Electric*
Roper 2384W3A Ranges, Electric*
Jenn-Air 2385EGN SURFACE UNIT- DDRAFT ELE
Jenn-Air 2385EGS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2390ERS SURFACE UNIT- DDRAFT ELE
Roper 2406*0A Ranges, Electric*
Roper 2406*1A Ranges, Electric*
Roper 2406*2A Ranges, Electric*
Roper 2406*3A Ranges, Electric*
Roper 2406W0A Ranges, Electric*
Roper 2406W1A Ranges, Electric*
Roper 2406W2A Ranges, Electric*
Roper 2406W3A Ranges, Electric*
Frigidaire 2408A GAS RANGE
Frigidaire 2408B GAS RANGE
Frigidaire 2408C GAS RANGE
Frigidaire 2409A GAS RANGE
Roper 2413*0A Ranges, Electric*
Roper 2413W0A Ranges, Electric*
Roper 2414*0A Ranges, Electric*
Roper 2414*1A Ranges, Electric*
Roper 2414*2A Ranges, Electric*
Roper 2414W0A Ranges, Electric*
Roper 2414W1A Ranges, Electric*
Roper 2414W2A Ranges, Electric*
Frigidaire 2418A GAS RANGE
Frigidaire 2418B GAS RANGE
Frigidaire 2420A GAS RANGE
Roper 2424*0A Ranges, Electric*
Roper 2424*1A Ranges, Electric*
Roper 2424W0A Ranges, Electric*
Roper 2426*0A Ranges, Electric*
Roper 2426*1A Ranges, Electric*
Roper 2426*2A Ranges, Electric*
Roper 2426W0A Ranges, Electric*
Roper 2426W1A Ranges, Electric*
Roper 2426W2A Ranges, Electric*
Frigidaire 2427A GAS RANGE
Roper 2428000 Ranges, Electric*
Frigidaire 2428A GAS RANGE
Frigidaire 2428B GAS RANGE
Roper 2438000 Ranges, Electric*
Frigidaire 2438A GAS RANGE
Frigidaire 2440A GAS RANGE
Frigidaire 2447A GAS RANGE
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Frigidaire 2448A GAS RANGE
Frigidaire 2448B GAS RANGE
Frigidaire 2450A GAS RANGE
Frigidaire 2450C GAS RANGE
Frigidaire 2450E GAS RANGE
Roper 2453*9A Ranges, Electric*
Roper 2453*AA Ranges, Electric*
Roper 2453W0A Ranges, Electric*
Roper 2453W9A Ranges, Electric*
Roper 2453WAA Ranges, Electric*
Roper 2454X0A Ranges, Electric*
Roper 2454X1A Ranges, Electric*
Roper 2454X2A Ranges, Electric*
Roper 2454X3A Ranges, Electric*
Roper 2456X0A Ranges, Electric*
Roper 2456X1A Ranges, Electric*
Roper 2456X2A Ranges, Electric*
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
Frigidaire 2458A GAS RANGE
Frigidaire 2467A GAS RANGE
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
Frigidaire 2468A GAS RANGE
Amana 2474.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 2475 SURFACE UNIT- DDRAFT ELE
Amana 2476.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 2477A GAS RANGE
Frigidaire 2478A GAS RANGE
Frigidaire 2478B GAS RANGE
Jenn-Air 2480 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2485 SURFACE UNIT- ELE
Jenn-Air 24882 JENN-AIR REFRIGERATOR
Frigidaire 2488A GAS RANGE
Jenn-Air 2490 SURFACE UNIT- ELE
Roper 2492*0A Ranges, Electric*
Roper 2492*1A Ranges, Electric*
Amana 2492.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 2492L0A Ranges, Electric*
Roper 2492L1A Ranges, Electric*
Roper 2492X0A Ranges, Electric*
Amana 2494.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.C MWAVE - FAMILY SIZE (60 HZ)
Amana 24940.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2496*0 Ranges, Electric*
Roper 2496*0A Ranges, Electric*
Roper 2496*1 Ranges, Electric*
Roper 2496*1A Ranges, Electric*
Roper 2496*2 Ranges, Electric*
Roper 2496*2A Ranges, Electric*
Roper 2496X0 Ranges, Electric*
Roper 2496X1 Ranges, Electric*
Roper 2496X2 Ranges, Electric*
Amana 24C3SS ROOM AIR CONDITIONER
Frigidaire 24CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 24DEMBWAD4 Tap(v1) / Electric Range
Magic Chef 24FA-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FA-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FA-6CKXWV8-DY RANGE- S/C MWAVE GAS
Magic Chef 24FK-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FK-6CKXWV8 RANGE- S/C MWAVE GAS
  #2 (permalink)
Old 01-25-2009, 06:41 PM
Junior Member
Default
I have read where others have had the same issue but I can't find a sufficient response to this question. Could someone please explain the cause of this? When the washer runs the complete cycle it will not begin spinning when the timer reaches spin cycle UNLESS I open and close the lid. At which time it begins spinning perfectly. I have replaced the lid switch with a brand new one and it still does the same. Can anyone help?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lady Kenmore 90 series fill problem bowtiecrazz Washer Repair 1 06-10-2009 08:42 AM
Kenmore 80 series won't spin Mike Ganoe Washer Repair 1 05-17-2009 11:28 AM
Kenmore 90 Series drum problem MattH Washer Repair 5 02-09-2009 08:49 AM
kenmore series 80 will not spin tlgeirna Washer Repair 1 06-04-2008 02:51 AM
Kenmore 80 series won't spin kenmorecrazy Washer Repair 0 03-15-2008 05:59 PM
