| » Leaking washer |
Model Number: WF306LAW/XAA Brand: Samsung Age: 1 - 5 years
My washer is leaking water from the bottom. I have a this problem before and the repair man said it was a filter that gets clog up and causes it to leak. I also called the samsung repair center and they said it would be found in the drain hose. I found a rubber black part not sure if that's it or not. I hope we can fix this without calling to have it repair. Thanks Lynn
Not a lot of experience with working on these models so about the best I can do is link you to a repair manual for a model that should be similar to yours.
https://secured.whirlpool.com/Servic...ier_Washer.pdf Hope this helps.
__________________
| Display Modes | |
| washer leaking | atucker2 | Washer Repair | 1 | 03-21-2012 08:28 AM |
| Washer Leaking | xela | Washer Repair | 2 | 12-10-2009 07:17 PM |
| Leaking Washer | echef75 | Washer Repair | 2 | 08-25-2009 05:32 AM |
| Kenmore elite washer is leaking under washer | cbs | Washer Repair | 1 | 07-12-2009 06:27 PM |
| leaking washer | rocco | Washer Repair | 2 | 10-13-2007 11:57 AM |
