hi my washer is leaking from the bottom. i have checked the hoses to and from in the back and they are dry to the touch. when in the final spin cycle it sounds as if there is a screw bouncing around inside the machine. also another problem isolated to one washing setting... were the water does not empty during the spin cycle ... i just do not use that setting anymore:( . thank you paula
