We have an Admiral washer we bought 2.5 years ago, but we only use it 6 or 7 months of the year. We have started to get small holes in our clothing after washing them. Any ideas what the problem is. We don't use bleach.
mike
like pin hole size or larger? maybe there is a screw or nail sticking up from a drain hole in tub
Originally Posted by: misterfixall like pin hole size or larger? maybe there is a screw or nail sticking up from a drain hole in tub Bigger than a pin hole. I had a pair of pants that came out of the dryer with a 1/4" x 1/2" hole. My wife had three small holes in a straight line that were about the size of the head of a pin or a bit larger. I also had a small square hole (1/4") in a shirt. mike
have you checked the condition of clothes when removed from dryer?
Originally Posted by: misterfixall have you checked the condition of clothes when removed from dryer? Yes, that is when we find the holes. Haven't checked the clothes out of the washer before we dry them. I was thinking maybe too much heat, but with some of the holes in a nice straight line, and no other signs of heat damage, it doesn't seem likely that the damage is done by the dryer. But then, I'm not expert and have no experience in this area. Thanks, mike
what make is dryer ? +how old . the older GE or moffat made black lines on clothes when front drum supports wore down
