Discuss
replace belt
 in
Washer Repair
this may be the model number wpre6100g0wt top load washer, Please tell me how to replace the bealt. THANKS Ads
Appliance Repair Forum > Appliance Repair Help > Washer Repair » replace belt
  #1 (permalink)
Old 05-06-2011, 01:21 PM
Junior Member
carey0413 is on a distinguished road
Default replace belt
Model Number: wpre6100g0wt   Brand: GE   Age: 1 - 5 years
Ads By Google
Related Models
General Electric WPRE6100G0WT Washer
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
General Electric WPSQ4160T6WW Washer
General Electric WPSQ4160T7AA Washer
General Electric WPSQ4160T7WW Washer
General Electric WPSQ4160T8AA Washer
General Electric WPSQ4160T8WW Washer
General Electric WPSQ4160T9AA Washer
General Electric WPSQ4160T9WW Washer
General Electric WPSQ4160TAAA Washer
General Electric WPSQ4160TAWW Washer
General Electric WPSR3090V0AA Washer
General Electric WPSR3090V0WW Washer
General Electric WPSR3090V1AA Washer
General Electric WPSR3090V1WW Washer
General Electric WPSR3100W0AA Washer
General Electric WPSR3100W0WW Washer
General Electric WPSR3100W1AA Washer
General Electric WPSR3100W1WW Washer
General Electric WPSR3100W2AA Washer
General Electric WPSR3100W2WW Washer
General Electric WPSR3120W0AA Washer
General Electric WPSR3120W0WW Washer
General Electric WPSR3120W1AA Washer
General Electric WPSR3120W1WW Washer
General Electric WPSR3120W2AA Washer
General Electric WPSR3120W2WW Washer
General Electric WPSR4130W0AA Washer
General Electric WPSR4130W0WW Washer
General Electric WPSR4130W1AA Washer
General Electric WPSR4130W1WW Washer
General Electric WPXH214A0CC Washer
General Electric WPXH214A0WW Washer
General Electric WPXH214F0CC Washer
General Electric WPXH214F0WW Washer
General Electric WPXH214F1CC Washer
General Electric WPXH214F1WW Washer
General Electric WPXQ3090T2AA Washer
General Electric WPXQ3090T2WW Washer
General Electric WPXQ3090T5AA Washer
General Electric WPXQ3090T5WW Washer
General Electric WPXQ3090T6AA Washer
General Electric WPXQ3090T6WW Washer
General Electric WPXQ3090T8AA Washer
General Electric WPXQ3090T8WW Washer
General Electric WPXQ3090TAAA Washer
General Electric WPXQ3090TAWW Washer
General Electric WR30X0259 Electric range
General Electric WR30X0280 Refrigerator accessory
General Electric WR30X0283 Refrigerator accessory
General Electric WR30X0284 Refrigerator accessory
General Electric WR30X0289 Refrigerator accessory
General Electric WR30X0290 Refrigerator accessory
General Electric WR30X0299 Electric range
General Electric WR30X0303 Refrigerator accessory
General Electric WR30X0304 Refrigerator accessory
General Electric WR30X0305 Refrigerator accessory
  #2 (permalink)
Old 05-07-2011, 05:31 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I cannot link you to a manual because GE does not allow access to its tech material, but here are the instructions. The diagrams will not copy, but I think they may be provided with the belt install tool which I recommend you using.
"Since the belt provides constant tension, there is
no need for adjustments (an adjustment method
is not provided).
A worn or damaged belt can result in excessive
brake time and will initiate a motor inverter
slipping belt error code. This code will prevent
the motor/inverter from operating.
To replace the drive belt it may be helpful to use
the belt install tool (part number WX05X10102.
To replace the drive belt using the tool kit:
Note:
If not using the belt install tool, follow steps 1
through 3, and 6 through 7. Remove wire tie after
step 7.
Disconnect power.
Remove the front panel. (See
Front Panel.)
Center belt on drive pulley and secure tightly
with wire tie as shown on following page. Align
wire tie as shown.
Stretch the belt install tool to fit over the end of
the motor shaft. (See Figure A.)
Slide belt install tool upward until it snaps into
the first groove of the motor shaft. (See Figure
B.)
Center belt on motor shaft grooves and slowly
turn drive pulley clockwise.
Continue rotating drive pulley until belt is fully
engaged.
Remove wire tie and belt install tool.
Note:
A new belt will be slightly smaller than the drive pulley.
A belt that has been installed on the drive pulley will stretch
to the diameter of the pulley over time. This is normal and
does not indicate a bad belt."
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace belt carey0413 Washer Repair 1 05-04-2011 05:31 PM
How Do I Replace Belt JAMES DRENKHAHN Washer Repair 2 11-04-2009 02:41 PM
How To Replace Belt ZEGATO Dryer Repair 0 12-21-2008 05:03 AM
Please! Help to replace belt..I think! 5december Dryer Repair 3 10-07-2008 06:11 PM
replace belt tomj1967 Washer Repair 0 02-02-2008 03:14 PM
