Is the spin cycle supposed to start when the washer tub is still full of water? Isn't it supposed to drain the water out first? It seems like it is putting an undo strain on the motor trying to start spinning while it is still full.:(
Yes, this washer drains and spins at the same time due to the way it's designed.
