Discuss
maytag will not spin agitate or pump
 in
Washer Repair
Our washer stopped in the middle of a cycle. Tub is full of water. When setting the timer any where
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag will not spin agitate or pump
  #1 (permalink)
Old 11-03-2007, 01:27 PM
drembo drembo is offline
Junior Member
drembo is on a distinguished road
Default maytag will not spin agitate or pump
Model Number: pav5158a   Brand: Maytag   Age: 1 - 5 years
Our washer stopped in the middle of a cycle. Tub is full of water. When setting the timer any where in the cycle, the washer makes some grinding type noises, and then the overload protection turns the thing off. The tub seems to spin freely by hand. Pump, agitator, and spin will not work.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-03-2007, 02:26 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
quite likely you have a pump that is frozen. relizing your tub is half full you might want to use a pail or wet dry shop vac to empty as much water out of it as you can. then tilt it back and see if the pump is free. try not to run it much or you will burn the motor out. part # for the pump if it is the pump is AP3447809. good luck and post your results here
__________________
  #3 (permalink)
Old 11-03-2007, 04:49 PM
Junior Member
Default
You are correct, sir!! It was/is the pump
  #4 (permalink)
Old 12-24-2007, 06:47 PM
slofeet slofeet is offline
Junior Member
slofeet is on a distinguished road
Default
washer fills up with water won't drain out and makes humming noise
  #5 (permalink)
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #6 (permalink)
Old 12-24-2007, 06:55 PM
Junior Member
Default
how do you know if the washer is frozen? and how can i fix it the washer will turn on and sometimes spin and makes a humming noise but will not drain water at all.
  #7 (permalink)
Old 12-24-2007, 07:08 PM
Junior Member
Default
you are crazy
  #8 (permalink)
Old 12-25-2007, 03:37 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Uh, drain the washer and check!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't spin or agitate BH5977 Washer Repair 3 11-03-2007 03:56 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 02:20 AM
no agitate no spin eveything else is fine. nonhandyman Washer Repair 0 10-11-2007 05:24 PM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Maytag Atlantis overflows - wont agitate Woody Washer Repair 4 08-27-2007 04:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
