Washer makes a banging noise in all cycles. The banging seems to be coming from the front of the machine near the motor. I have observed it with the front cover off and the belt seems to be getting looser also. Any help would be appreciated.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I would check the belt. See if it has chunks missing out of it or if it is burnt. A belt going bad can make quite a bit of noise.
The belt is in really bad shape. Almost cut through in a few places.
Is replacing the belt pretty straight forward.
