| » washer stopped after 'wigwag' alarm, now won't run |
Model Number: 110.82172810 Brand: Kenmore Age: More than 10 years
Allegedly 'heavy-duty' washer had been having 'wigwag' issues on 'heavier' loads [like any towels at all in mix]. Is level. Would start after redistributing the load. Today it 'wigwagged', then wouldn't restart even after heavy items removed. Now it just makes a low buzzing sound, like the wigwag alarm only much softer-- like a solenoid is making contact but no follow-through from the motor or tranny.
Is this a basket drive/brake issue, snubber problem, or something easier/less expensive to diagnose/repair? P.S. have already bypassed lid switch, since that was a previously-failed part. |
this is an update, since i 'solved' the problem [temporarily, anyway]. turns out this belt-drive whirlpool model has a 3-point ball/socket/rod suspension system for the tub; the lower balls were very compressed, so i switched them with the top sets, and lubricated all the balls/sockets with white lithium grease. spin cycle then ran fine. only problem--whirlpool no longer makes the rubber balls, so can't replace the old ones--a shame because this 25 year old washer still runs strong.
| Display Modes | |
| dryrer stopped mid stream | flippinstick | Dryer Repair | 2 | 11-02-2007 11:44 AM |
| my washer stopped draining or spining | jesse | Washer Repair | 1 | 10-09-2007 03:16 AM |
| ice maker stopped working | pavelj539 | Refrigerator & Freezer Repair | 0 | 09-23-2007 04:33 PM |
| washer stopped spinning | leagleson | Washer Repair | 0 | 09-04-2007 11:18 AM |
| Norge Range alarm won't turn off | leooneil | Oven Repair (including Ranges and Cooktops) | 0 | 08-26-2007 10:59 PM |
