Discuss
LG Front Load-LE Code- Drum wont turn
 in
Washer Repair
I have an eight year old LG front load washer with a LE code displaying ( overload ). I have
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG Front Load-LE Code- Drum wont turn
  #1 (permalink)
Old 05-03-2011, 06:51 AM
Junior Member
sleddoc is on a distinguished road
Default LG Front Load-LE Code- Drum wont turn
Model Number: WM2077CW   Brand: -other-   Age: 5 - 10 years
I have an eight year old LG front load washer with a LE code displaying ( overload ). I have one towel in the drum. The motor makes a slight whining sound and the Drum will not turn or rocks very little. I think it has a bad stator but am not sure. Is the stator hard to replace ? Is it likely this is my problem, do these fail ? Any help would be appreciated.
Thanks,
Dave.
Related Models
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
 WM2233HU Washer
 WM2233HW Washer
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
 WM2442HW Washer
 WM2455HG Washer
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
  #2 (permalink)
Old 05-03-2011, 02:18 PM
Junior Member
Default Found an answer
I googled - LG Tromm front load washer drum won't spin and found out what is probably my problem - the resistance of the stator checks out, 5-15 ohms. I am going to replace the Hall affect sensor - Motor position sensor.
  #3 (permalink)
Old 05-13-2011, 08:06 AM
Junior Member
Default Solution
The Hall Sensor was definately the problem. I replaced it a week ago and have had no Issues since. I did apply blue loctite to the 17mm bolt holding the rotor on. There was some blue loctite on the bolt from when the washer was built. I also applied conductive grease to the Hall Switch connector pins to ensure a good connection.
  #4 (permalink)
Old 05-28-2011, 06:30 AM
Junior Member
DAC68 is on a distinguished road
Default Similar issue?
Quote:
I have a 6 year old LG front loader with I think a similar issue. Very little in the drum, motor makes similar sounds. Doesn't seem to spin up to high extractor speed. Displays the LE code when overloaded and won't spin at all. Basically the motor seems weak. Do yo think the Hall effect sensor or both the stator and sensor? Thanks
  #5 (permalink)
Old 05-31-2011, 07:06 AM
Junior Member
Default Replace the sensor
I would replace the sensor. It is about 25 to 30 bucks and from all of the postings on the internet from people with the LE code and sensor problems, that should fix it. Mine is still running perfectly.
  #6 (permalink)
Old 05-31-2011, 08:13 AM
Junior Member
TALLIANN is on a distinguished road
Default
I have an lg washer it started making a loud noise and was spinning out very fast now washer stopped totally had LE code will not drain or do anything need help fast
  #7 (permalink)
Old 05-31-2011, 09:08 AM
Junior Member
Default Not Sure
Mine didnt make any noise before it stopped. It started displaying the LE code at the begining of the wash cycle. Was the noise because the load was not balanced ? you could try removing some of the clothes and see if it restarts. The service manual has some diagnostic steps that might help, you can search and find it online.
  #8 (permalink)
Old 05-31-2011, 10:14 AM
Junior Member
Default
Quote:
try everything still will not move LE CODE water did not drain either
  #9 (permalink)
Old 05-31-2011, 11:13 AM
Junior Member
Default
I have seen people posting that if you spin the drum around manually 4 or 5 times they will start working again. Not a permanent fix but it might get the water drained. The manual has the specs for the Stator coil - its 7-15 ohms of resistance between the wires on the plug. You could check that and verify that the stator is good and replace the hall sensor, thats what I did, but I dont know how to explain the loud noise.
  #10 (permalink)
Old 05-31-2011, 12:08 PM
Junior Member
Default lg washer le code
what do you think could be making this noise
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidare front load wont turn on mikebaily Washer Repair 9 08-19-2010 05:19 PM
drum repair on a front load frigidare. kfoell Washer Repair 2 07-06-2010 05:00 PM
front load GE drum wont spin even by hand robr Washer Repair 2 06-30-2010 07:48 PM
Front Loader drum wont turn jtoddrn Washer Repair 3 04-13-2010 01:38 PM
Front load drum springs installation gbryant Washer Repair 3 04-22-2009 11:13 AM
