Washer leaks when it spins. Had it a week.
Originally Posted by: vceldredge Washer leaks when it spins. Had it a week. VC, Do you see the water leaking from the bottom of the washer panels, or just water on the floor. Check the drain hose and drain pipe first, you may have a slow drain or the end of the hose may not be seated properly in the pipe. You may have to remove the front panel and observe the washer operate and see where the leak is. To remove the front panel slide the washer out a few inches, with a putty knife or simillar tool, insert the tool in the seam between the top and front panel, and press in on the spring clips(1 on each side, approximately 3 inches in from the corner) and raise the top,so you can access the 2 5/16" screws holding the panel to the top cross brace.pull the top of the panel out towards you and lift it up off the bottom clips. Good Luck, :) :) :)
