Discuss
bearings / seal replace
 in
Washer Repair
How to download the Repair Manual for Kenmore - front loaded washer, year 2002. The bearings at the rear tub need
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bearings / seal replace
  #1 (permalink)
Old 11-02-2007, 10:04 PM
gandra gandra is offline
Junior Member
gandra is on a distinguished road
Default bearings / seal replace
Model Number: 970-C41062-00   Brand: Kenmore   Age: 5 - 10 years
How to download the Repair Manual for Kenmore - front loaded washer, year 2002. The bearings at the rear tub need to be replaced, I want to do it myself, step by step. Thanks in advance!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-02-2007, 11:02 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
you have an incorrect model #. your model # should be around the door opening as it is open. more than likely the model # will start with 110. or 417. please re check it and post the correct model # here.
__________________
  #3 (permalink)
Old 11-03-2007, 04:59 PM
Junior Member
I found a sticker on the door frame, with model No. 970-C41062-00, made in USA 08/02, some people told me it might be 417.42042100 or 417.41042000.
Is it possible to find the Repair Manuals for these models?
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace the tub seal on Whirlpool washer if9566 Washer Repair 2 10-10-2007 08:39 PM
replace tub seal lhurt Washer Repair 4 10-08-2007 07:39 AM
Mah3000aww Maytag Neptune/bearings,leak Tinamd Washer Repair 0 10-01-2007 11:30 AM
How to replace front seal on Kenmore washer gwalia Washer Repair 1 09-09-2007 11:45 PM
can't get washer apart to replace seal kay Washer Repair 4 09-05-2007 05:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
