Discuss
error codes on whirlpool duet sport
 in
Washer Repair
Hi Thad The complete troubleshooting instructions you can find in the service and repair manual . Gene. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » error codes on whirlpool duet sport
  #1 (permalink)
Old 11-02-2007, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Brand: Whirlpool   Age: Less than 1 year
Hi Thad
The complete troubleshooting instructions you can find in the service and repair manual.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #2 (permalink)
Old 07-31-2010, 07:57 PM
Junior Member
nsdllc is on a distinguished road
Default
Quote:
Originally Posted by Thad Steele View Post
I am getting an F 28 error code on my duet washer. This is supposed to be a communication error. I replaced the CCU board and no change. I had a low voltage occurrance around the same time the washer crapped out. The door lock also failed, could this failure cause the communication error code?
Download the manual first. Unplug washer and remove the front panel. On page 56 of 96 of manual you will see a picture of the drain pump assembly. To the right is a flip-top cover that is holding wire connectors plugged into the terminal. If the cover is UP, push it back down. PROBLEM SOLVED! The F28 is a communication error code. In my situation, it was loose connectors because the flip-top cover popped up somehow.
This is the 2nd time it happened to me. The 1st time I called a repair guy and I think I paid him about $150-$200?? It looks like he applied duct tape to hold the cover in place. That is how I noticed it.
Push it back down into place and it just might work for you. It did for me!!
  #3 (permalink)
Old 10-09-2010, 08:56 PM
Junior Member
mackattack11 is on a distinguished road
Default Error code f28
I was getting an error code f21 regarding the drainage problem in the washer. After my husband successfull emptied the clean out, we started getting an f28 error code. We tried everything that was posted here on the internet. We still had the front panel off while attempting to check the drainage problem. We then started to check off every f28 error code out there. We were at our wits end when I realized that there is a switch on the left side of the inside front panel that lets the washer know whether or not the front panel has been put back on. We put the front panel back on and it worked fine. We were ready to call a repairman because we just hadn't replaced the panel itself. Hope this helps.
  #4 (permalink)
Old 05-09-2011, 09:01 PM
Junior Member
Masterblaster8 is on a distinguished road
Smile Put everything back together!
mackattack11. You were correct. We almost called repair man, but you saved us probably 200 bucks.
I initially got f-21 code ( pump messed up). I bought new pump and put it on (first time novice), and started getting f- 28 code ( main brain screwed up).
Putting front back on was all it needed!
Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport Error Code F30 rayp11n Washer Repair 14 04-25-2012 04:09 PM
Whirlpool Duet Sport ht washer gottago4itnow Washer Repair 3 01-14-2010 03:47 PM
Whirlpool Duet Washer error codes F11 and DL tka1121 Washer Repair 1 12-30-2009 07:58 AM
Whirlpool Duet Sport washer F-01 error Penypincher Washer Repair 1 09-24-2009 04:43 AM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 07:20 AM
