GE Wcrd 2050D1wc top load washer the problem is it wont spin but it does agitates, and drain. when spin cycle comes on a click noise comes on like if it is trying to rotate the agitator for a spin but it can't start spinning by itself so i had to manually turn the agitator for a startup and it will spin and work fine. My question is it the capacitor not sending enough power to the motor or the motor is weak or it has gone bad. I also had checked the lid switch shows continuity when lid is closed. washer is clutchless need some suggestion please
Neal
Originally Posted by: patel1974 GE Wcrd 2050D1wc top load washer the problem is it wont spin but it does agitates, and drain. when spin cycle comes on a click noise comes on like if it is trying to rotate the agitator for a spin but it can't start spinning by itself so i had to manually turn the agitator for a startup and it will spin and work fine. My question is it the capacitor not sending enough power to the motor or the motor is weak or it has gone bad. I also had checked the lid switch shows continuity when lid is closed. washer is clutchless need some suggestion please
Neal Neal, Since this is a commercial(coin op) washer, and based on your post, You need to start at the belt and motor assembly, Part number: AP2044592
Part number: AP3205861
They are the most likely parts causing your slow / no spin situation. Good Luck, :cool: :cool: :cool:
