I have a Tappan Model TWX233RBW1 and it was making a very loud noise for a long time when it was in spin cycle and then it finally would not spin and noise stopped i was thinking it is the drive belt but not sure and if that is what it is how do i get to the damaged belt to replace it? Please help family of 6 and need washer back. tHANK YOU
The front panel will come off, either by screws at the bottom or by releasing clips that hold it to the cabinet. If it has the clips, insert a screw driver in the gap between the top and front near the edges.
You will now be able to see if there is a problem with the belt, or something caught in between the tub and basket.
