Discuss
Kenmore Front Loading Washer
 in
Washer Repair
Is there any part in my front loading washer that can only be accessed/seen by taking the top off, that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Front Loading Washer
  #1 (permalink)
Old 04-28-2011, 11:04 AM
Junior Member
ANDREA1 is on a distinguished road
Default Kenmore Front Loading Washer
Model Number: 41741142000   Brand: Kenmore   Age: 5 - 10 years
Is there any part in my front loading washer that can only be accessed/seen by taking the top off, that would cause the entire drum to move back and forth? I have taken off the bottom front panel and back, and shocks, springs, bearing seem okay. It is definitely looser at the top of the drum, but can't see anything loose or broken from the back. Washer started knocking a week ago during spin cycle, but works fine otherwise. Also, there is no grinding or anything when manually turning the drum.
Ads By Google
Related Models
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
  #2 (permalink)
Old 04-28-2011, 12:35 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Andrea,
Your washer has 2 suspension springs on the front of the washer tub.
You can see and access them once you have removed the top of the machine.
Removing the top panel:
1. Disconnect the washer from the electrical supply.
2. Removethe (2) screws fromthe rearof thetop, slide
the top back and lift it off.
Suspension spring - This front load washer suspension spring includes the insulators on each end and are located toward the top in the front supporting the drum. It is recommended to replace both springs at the same time for even wear. Also consider checking the rear suspension springs as well.
Part Number: AP3212517
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-29-2011, 09:12 AM
Junior Member
Default
Quote:
Originally Posted by Joe / APP Team View Post
Andrea,
Good Luck,
Hi Joe
I can see the springs from the back and they "look" okay. They move along with the tub, but don't look stretched or too worn. Shouldn't they move a little or are they supposed to be SO incredibly tight that they shouldn't move at all? I also don't see any rear suspension springs. There are two springs holding the tub up and two shocks supporting the tub. Then of course the moter, hoses, etc. That's why I wondered if there was any other spring or attachment that I couldn't see that maybe held the top front of the tub a little tighter. I have my dryer on top of my washer so I was hoping not to move it unless there was something I couldn't see from the back or bottom front.
  #4 (permalink)
Old 04-29-2011, 12:01 PM
Senior Expert
Default
Hi Joe
Andrea,
Everything sounds "normal" the springs are designed to be a little "tight" or stiff.
There are counter weights mounted to the front and back of the tub, you should've seen the rear counter balance when you had the back off, the screws could be loose and the weights may be shifting, did you hear any scaping or clunking noise when the tub was shifting ?
Theres not a lot you can do, until you dismount the dryer from the washer, all the remaining access points are through the top or front of the washer.
This problem is consistant, it wasn't just a couple of loads, correct ?
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 04-29-2011, 05:21 PM
Junior Member
Default
I can see the weight on the back, but obviously not the front until I move the dryer. I will have my husband do that tomorrow and see what we find. Everything does look normal. There is nothing noticably loose or broken.
The banging started a a week or so ago. I was washing a blanket and just assumed it was because the load was uneven; but then it did it with the next two loads which were normal size. I put it on the spin cycle a few times with nothing in it, and the same banging occurs. Then when I took the back off, I put it on the spin cycle for a few seconds and the banging stopped (it was apparently hitting against the back), but the tub was bouncing all around.
  #6 (permalink)
Old 04-30-2011, 12:36 PM
Junior Member
Default
Okay, so looking at everything from the top doesn't help either. There is nothing I can see that would make the tub so loose, unless that is the normal movement of the tub. Although its obviously hitting the back, which it never did before.
  #7 (permalink)
Old 05-02-2011, 06:56 AM
Senior Expert
Default
Andrea,
There is some back and forth movement / tolerance, but not like you're describing.
Thats, usually a good indication of a gross overload, but usually returns to normal, at this point you're going to need to look at the shocks and the mounts, make sure they're not bent and the tub mount for cracks, also check the "boot" gasket between the tubs in the front loading door. check to see if it got twisted,bunched up or has come loose.
Good Luck,
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 05-02-2011, 09:49 AM
Junior Member
Default
I ran a load of laundry yesterday with the back off and it made the same banging noise. I actually sat by the washer during the whole wash to see if I could figure it out. It now sounds like it's something in the tub itself moving around. Is there something in the tub that could've come loose or broken off? I'm thinking thats not something I should try to fix myself?
  #9 (permalink)
Old 05-02-2011, 12:26 PM
Senior Expert
Default
Andrea,
There's nothing between the tubs that could break off, you may have something between the tubs, but that should cause a "drag" on the tub, not a back and forth movement. Did you check to see if one of the baffles in the tub is loose or broken ? If we can't see anything obvious, it may be time to get some new eyes on the subject.
__________________
Joe M. APP TEAM
  #10 (permalink)
Old 06-06-2011, 07:14 PM
Junior Member
siqon is on a distinguished road
Default same problem, followed the generous advive but...
hi same problem, followed the generous advive but...
open the back and top, started a load but the clunking seen to come from the inside between the tub and the tub plastic "cover" cause nothing touches the structure... is it off balance ? cause the counter weight seen ok?
althought the belt seen tight its runing off (toward inside) but its runing well turning the drum while open ???
help pls! and many thx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Loading Washer Model #417 kuzmic@flash.net Washer Repair 0 02-06-2011 03:02 PM
Kenmore front loading washer coin operated. paka808 Washer Repair 0 10-03-2010 04:51 PM
Kenmore elite front loading clothes washer dtwilliams Washer Repair 1 08-03-2010 01:10 PM
Kenmore front loading washer won't drain vince123 Washer Repair 5 05-14-2009 12:04 PM
Kenmore front loading washer noisy bobbiraej Washer Repair 1 01-21-2009 03:22 AM
