Discuss
Whirlpool washer leaks from front while filling
 in
Washer Repair
Top loading washer leaks from the bottom when filling - water drips from the front panel in about the middle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer leaks from front while filling
  #1 (permalink)
Old 04-27-2011, 01:08 PM
Junior Member
bobandjayne is on a distinguished road
Default Whirlpool washer leaks from front while filling
Model Number: LSL9345EQ0   Brand: Whirlpool   Age: 1 - 5 years
Top loading washer leaks from the bottom when filling - water drips from the front panel in about the middle of the machine. Does not pour out profusely - but more than just drip-drip. It almost appears to be leaking from the tub - but why only when it is filling? Is there a valve or something in the front of the machine that could be stuck? Or is a filling hose routed in such a way that it could be leaking from the bottom front of the machine when filling? Thanks for any pointers...
Ads By Google
Related Models
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
  #2 (permalink)
Old 04-27-2011, 06:36 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The machine is designed so that it will operate with the cabinet removed. Here's a video that will guide you through the cabinet removal process. All you will need to do is bypass the lid switch (with a jumper wire) and watch it during a fill cycle. You should be able to spot where the water's coming from.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
  #3 (permalink)
Old 04-28-2011, 01:19 PM
Junior Member
Default washer fixed - thanks
Pulled the cabinet as suggested - ran through a fill cycle (did not need to bypass lid switch for filling - but did need to for draining tub) - as the tub filled - water was leaking from the pump. Replaced pump - problem solved. Thanks for the help - the video was also very helpful.
  #4 (permalink)
Old 04-28-2011, 01:46 PM
Senior Expert
APP Volunteer
Default
Glad to help. You saved a bunch of money on a professional service call by doing it yourself. Well done!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer leaks as soon as its filling TonyCud01 Washer Repair 1 04-03-2010 02:47 PM
Washer leaks after filling if it is not started BarbD Washer Repair 0 03-23-2009 10:24 AM
Washer will not stop filling and tub leaks t7433 Washer Repair 1 03-13-2008 11:16 AM
Washer leaks when filling and draining jds.girl_2006 Washer Repair 1 02-11-2008 04:25 PM
Washer leaks when filling and draing jds.girl_2006 Washer Repair 1 02-11-2008 04:24 PM
