Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Remove lower washarm (http://forum.appliancepartspros.com/washer-repair/212571-remove-lower-washarm.html)
jdherman 04-27-2011 12:04 PM
Need to remove lower washarm for cleaning/replacement and there is a foreign object rattling around. Appreciate any guidance.
Thanks.
Joe / APP Team 04-27-2011 01:20 PM
Quote:
Thanks.
JD,
Once you remove the lower dishwasher rack, in the center of the spray arm assembly, there is a LARGE retaining nut, turn the nut counter clockwise and it will unscrew, don't loose the small Nozzle inside, lift the arm and cover of the top then separate the arm from the cover.
Good Luck,
